B18C1 Rebuild time, Need advice
Old Nov 14, 2010 | 08:18 PM
mafia's Avatar
Default B18C1 Rebuild time, Need advice
Hey guys my daily driver GSR DB8 is smoking on start up's, And antifreeze Is leaking by the timing belt area. SO what I have so far.
Fully built head Ported too (new dual springs and retainers and valve guides)
Usdm ITR pistons (used but who cares)
Golden eagle light weight crank balanced
Wanna be ITR I'M.
OEM timing belt
OEM water pump
Things I'm going to buy any day now
ARP ROD bolts
OEM head gasket
OEM Rings
ACL RACE bearings
1) SO What I need to know is do rods and pistons need to be balanced? because crank Is brand new and balanced. That is pretty much what I dont really get.
2) And If I dont buy ITR cams Is a tune a must? Will I be good on my stock GSR ecu or just get a ITR ecu or maybe a chipped plus a tune?
I need this car to last me like forever
Old Nov 14, 2010 | 08:36 PM
ruffrhyder's Avatar
Default Re: B18C1 Rebuild time, Need advice
Wanna be ITR I'M.
OEM timing belt
OEM water pump
ARP ROD blots
OEM head gasket
OEM Rings
ACL RACE bearings
If you want it to last, have the entire rotating assembly balanced and get the car tuned. Do not use a stock gsr ecu or gsr basemap with ITR pistons and cams.
Old Nov 14, 2010 | 08:46 PM
mafia's Avatar
K thanks, I was not sure If the entire rotating assembly needed to be balanced or not. As for the Tune, I will get it tuned because I drive this car all over the US so I dont need it to break down somewere. SO with ITR pistons Ill be at 11.0:1 right?
Old Nov 15, 2010 | 10:39 AM
fv8s's Avatar
with p73's you be closer to mid 11's if your head is the Gs-R from your DB8. Your CR will also be determined by deck height/ HG
Old Nov 15, 2010 | 11:31 AM
mafia's Avatar
yeah Its a GSR Head, Block, rods, crank. With P73 USDM ITR pistons. I checked some site It told me 11.04:1 that sound right? Thats not really mid 11 ratio thow :/
Old Nov 15, 2010 | 11:32 AM
fv8s's Avatar
Sounds pretty close. Those compression calculators are NEVER right
Old Nov 15, 2010 | 02:05 PM
neverstop's Avatar
you should absolutely get it tuned man, PLUS getting your car tuned is the best hp per dollar you will ever spend. the mid range power i got in my gsr cam'd ls vtec even from the crappy DNR tune was like night and day. after I got it tuned I was seriously pulling off the freeway and getting back on just because I couldn't believe the power difference.
balancing everything isn't REQUIRED but certainly a good idea if you have it all apart. not too expensive either.
kaminsknator
Engine Machining & Assembly
Oct 28, 2017 02:01 PM
CRISxMOB
Feb 4, 2012 09:37 PM
98CivB18C
Feb 3, 2012 12:36 PM
moptrf
Dec 1, 2010 07:51 AM
.I.Need.Money.
Apr 28, 2007 10:38 AM
