Quick turbo ?
So my buddy chad just boosted his b20 teg. He has a golden eagle vacuum block. He ran separate vacuums to every things is that ok? also is the waste gate always supposed to dump exhaust out of it?
The wastegate is supposed to let excess pressure out of the system to ensure that you maintain steady, reliable boost. If you're running at 15psi, the gate should open at +15. If it's opening sooner, you're not hitting 15psi. If it's constantly open, you're not building boost at all.
V-SPEC 1
Feb 19, 2013 07:43 PM
