will my d series throttle body work on my b18b1
Wait, what? How do we get cable out of throttle body?
Yeah you can use the D series throttle body on a B series...you can use a B series on a D series. You can use a F or H series also on either. I'm just not sure why someone would want to use a smaller throttle body. If you're scrounging to get the motor running, go ahead. If your B series is acting up, you can salvage the TPS and MAP and put them on the B series.
You can get a B series throttle body pretty cheap. I can get them for $15 at my local junkyard.
The bolt pattern is the same. I believe it goes something like VX < CX < LX/DX/SI < B18 LS/B20 < GSR <ITR < F/H series < K series < mustang 90mm
If anyone has measurements, please post. I probably have at least a couple wrong there.
yeah im gonna swap over the sensors then, they wont give me any problems? had a hx motor in it now have a b18b1 both obd2
blu3g
Aug 17, 2005 04:00 AM
keepitjdm
Apr 13, 2005 02:40 PM
