Suspension & Brakes Theory, alignment, spring rates....
97 Ek civic rear toe left side is WAY off?!
Old Nov 13, 2010 | 07:01 PM
Hondaruss's Avatar
Default 97 Ek civic rear toe left side is WAY off?!
Here is my delima.. I bought a 97 civic ek shell I am turning in to weekend drag car. I was in the process of putting a different set of wheels on the car. I started with the left rear. got it on set the car down off the jack and looked at it the front of the rim is pointing out like this ( \ ) I never noticed it with the steelies on the car.. so i took the rim off and put the steelie back on and looked and the steelie is doing the same thing. Now at this point I was soo mad i dropped everything and went inside.
What are some things i can check/ measure to find out if its the suspension that is wacked or the chassis. Also i seen the trailing arm assembly that goes to the compensator arm says 94 on it with junk yard marker.. so its making me wounder if this chassis isnt messed up. Also wondering is the 94 civic compensator arm is different from the ek one causing the excessive toe on this side.
I have googled rear conversions just to see if anyone has made mention of the compensator arms being different but i haven't found anything
Any help would be greatly appreciated
Russ
Old Nov 13, 2010 | 08:21 PM
98civdx's Avatar
Master Detailer
Default Re: 97 Ek civic rear toe left side is WAY off?!
You need to get an alignment. My friend is runing my old compensator arms on his eg without any issues.
There is a couple of reasons it could have been replaced, hitting a curb or somthing is one.
Or have you looked at your arms? Maybe move them and see if it gets better?
Old Nov 13, 2010 | 08:31 PM
Hondaruss's Avatar
I am going to check it over tomorrow I guess the comparator arm bolt holes are slotted and are able to slide. i am going to see if i can get it close to where it needs to be (relatively) so we will see what happens
Old Nov 13, 2010 | 08:52 PM
98civdx's Avatar
Master Detailer
Yep, that is how you adjust the toe. If you get it close, take the car in and get it aligned just to make sure it is perfect.
EL2
Oct 18, 2015 09:49 AM
calumthestrong
Suspension & Brakes
Mar 8, 2013 03:51 PM
xbabysharkx
Dec 15, 2010 12:41 PM
DAgsr
Suspension & Brakes
Oct 10, 2006 03:51 PM
