Put in another cam today...but belt keeps slipping for some reason????
Old Sep 21, 2002 | 04:44 PM
sporkcrx's Avatar
Default Put in another cam today...but belt keeps slipping for some reason????
I installed another cam this morning, but for some reason, even when i turn the engine over by hand, the belt slips by about 7 teeth, each time I turn the engine over (by hand) it slips to a new spot...what the hell is going on here??? I installed my old cam months ago with no problems, the only thing I can think of that I did differently was when the belt was off the cam gear...I turned the engine a little by pulling on the belt to line it up with the cam gear, then slipped it on...everytime I turn it over by hand it slips a lil....anyone know what the cause is of this?
Old Sep 21, 2002 | 04:47 PM
zcivicz's Avatar
Default Re: Put in another cam today...but belt keeps slipping for some reason???? (spoon2)
try the belt tensioner, it should fix it
Old Sep 21, 2002 | 04:49 PM
sporkcrx's Avatar
Default Re: Put in another cam today...but belt keeps slipping for some reason???? (zcivicz)
well i tightened the tensioner....but you think it could of gotten messed up when I pulled on the belt? anyway to check if it's working right? the belt has tension, it doens't come loose or anything.
Old Sep 21, 2002 | 04:52 PM
zcivic91's Avatar
check the tensioner underneath...theres alil nub on the block..make sure the hole in the tensioner is on the nubb..
Old Sep 21, 2002 | 04:53 PM
bryant's Avatar
Default Re: Put in another cam today...but belt keeps slipping for some reason???? (zcivic91)
make sureyour spring is okay and still springy
Old Sep 21, 2002 | 05:30 PM
sporkcrx's Avatar
Default Re: Put in another cam today...but belt keeps slipping for some reason???? (CR-X)
Ok...if you make a mark on the tooth of the timing belt that's right above the "up" mark on the cam gear, when it comes back around, should it line again???
Old Sep 21, 2002 | 06:58 PM
Digitalcivic's Avatar
sohc or dohc? cuz i was being stupid when i installed my belt on my dohc and didn't relize I had to go around twice (by hand) before it would line up again.
Old Sep 21, 2002 | 08:47 PM
Chiovnidca's Avatar
No.
Old Sep 22, 2002 | 04:22 PM
sporkcrx's Avatar
Default Re: Put in another cam today...but belt keeps slipping for some reason???? (Chiovnidca)
whew..well everything is fixed now, no bent valves from moving the belt around so much, compression was 150 across.
boomersz
Feb 24, 2007 08:19 PM
Racermech
Jun 25, 2006 04:33 PM
JCracer723
May 15, 2004 06:51 PM
JONBLAZE55555
Nov 9, 2003 12:27 PM
AdamITR
Aug 28, 2002 07:11 PM
