comp cams
Old Nov 13, 2010 | 12:56 PM
hello1320's Avatar
Default comp cams
6 yrs ago i decided to try the comp cams stage 3s 5300 is the cam # I think. The motors a 84.5x89. Gsr ported head, victor x intake with 70mm tb. 14.7 comp...AnR side exit header
It made 207 and 139. This was on some 118 track fuel.....were switching to q16 and swapping the cams
Has anyone used these cams ???. Iam sure the power is down cause the cams
Old Nov 14, 2010 | 09:51 AM
TheShodan's Avatar
Moderator
Default Re: comp cams
Comp Cams got bought out shortly after you bought those, so there more than likely not many if at all, using those. They never really good with import applications, unfortunately.
Old Nov 14, 2010 | 03:36 PM
lohatch's Avatar
i made 270hp/185tq with the 57400's and a 2.2L. i dont have any experience with the 57300's.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/270hp-185tq-bseries-2672009/
Old Nov 15, 2010 | 11:35 AM
fv8s's Avatar
wow those numbers are low for that setup
Old Nov 15, 2010 | 12:28 PM
racebum's Avatar
it's just the cams. comp makes great v8 cams but never really hit a powerful grind with honda. everyone interested in power seems to be leaning on a jun3-ish grind, skunk pros or rocket
Brangin
Nov 18, 2016 12:45 PM
LUVMYEG206
May 22, 2013 01:42 PM
rough_draft
Aug 22, 2004 12:00 PM
Red99CivicSi
Oct 24, 2003 12:36 AM
