Heat Broke!
Old Nov 13, 2010 | 12:38 PM
xkellyxveitx's Avatar
Default Heat Broke!
So last night. My heat stopped working randomly. I'd noticed before that I'd start my car in the morning, go back inside and get ready, and then go back out to the car, and the heat wouldn't be blowing out, and it wouldn't start blowing until I turn it off then back on.
Checked the heater motor fuse today, and all other fuses, and everything was good.
Removed the blower motor, and it runs still off a battery.
Tested the voltage at the connector for the motor, and there is nothing. There is a little >1V spike when I first switch the heat on, and then it drops.
Anyone have any ideas? It's starting to get chilly.
Old Nov 13, 2010 | 03:48 PM
Tyson's Avatar
Default Re: Heat Broke!
Check the faq.
Old Nov 14, 2010 | 07:44 AM
I knew someone would say that..
I saw three heat related threads.
1. This one is no help
2. This is no help. There is no power getting to the blower at all.
3. This is one doesn't describe my problem, but I got a new resistor on the way just because I can't think of anything else.
Old Nov 14, 2010 | 07:58 AM
FSRslug's Avatar
How did you check for voltage?
Old Nov 14, 2010 | 08:43 AM
Multimeter, right at the connector that plugs into the blower.
Old Nov 14, 2010 | 10:49 AM
FSRslug's Avatar
lol, I figured that, but was the ignition "ON"? So no voltage between the 2 connector terminals. What about the Blu/Wht and a good body ground? If there is no voltage between the Blu/Wht pin and body ground, then the there is an open in that wire somewhere between the connector and the ignition switch.
Old Nov 14, 2010 | 09:05 PM
Car was running when I tested it. Didn't check any other wires. New resistor will be here tomorrow. If it doesn't work then I shall check.
bodiez
May 13, 2008 07:27 PM
LS94tegra
Feb 6, 2008 05:56 AM
philosofy1
12
Jul 28, 2006 11:57 AM
riceboyEFsi
Jan 25, 2004 03:20 PM
Sedat1ve
Dec 11, 2002 06:38 PM
