Who is running Energy Suspension Trailing arm bushings?Help
Old Sep 21, 2002 | 04:25 PM
crxjdmsir's Avatar
Default Who is running Energy Suspension Trailing arm bushings?Help
I bought the Energy Suspension bushings for the rear trailing arms and something just doesn't seem right. There are no directions w/ them either. All the box says is to use all old metal hardware. But still doesn't look right. The center hole looks to small and they enclosed 2 metal sleeves that will definately not fit on the peice that bolts to the car. Please help w/ pics if possible. Thanks to everyone who helps.
Old Sep 21, 2002 | 05:27 PM
FourthGenHatch's Avatar
Default Re: Who is running Energy Suspension Trailing arm bushings?Help (crxjdmsir)
I bought them to use on my Teg trailing arms and I have no idea how you would get these in there, it makes no sense to me either.
Old Sep 21, 2002 | 06:05 PM
jc836's Avatar
Have them on my 89 CRX Si and it is not a lot of fun putting them in. Actually, my fabricator (ITA builder) did it and he had to take the arms off the car to remove the old bushings. You have to get the center pin out and clean off all the rubber stuck to it and cut the rubber out of the shell. Once everything is clean the new bushings slide in without a lot of fanfare. A press would be nice. If you are going this far, get a set for the lower control arms too as this will definitely tighten things up. Don't do any others until you are certain that you need them-the front can bind on road courses-so rubber is better there except for the radius rods and sway bars.
Good luck
Old Sep 21, 2002 | 06:19 PM
Mugen Dom's Avatar
Default Re: Who is running Energy Suspension Trailing arm bushings?Help (jc836)
hey look wut i found after searching once...
Old Sep 21, 2002 | 06:59 PM
E-AT_me's Avatar
Default Re: Who is running Energy Suspension Trailing arm bushings?Help (JdMB16Ahatch)
hahahaaaa
i have prothane units.. they have new hardware and instructions.. boy am i spoiled!!
Old Sep 21, 2002 | 07:00 PM
Mugen Dom's Avatar
Default Re: Who is running Energy Suspension Trailing arm bushings?Help (Rexman)
mine came with instructions from summitracing
Old Sep 21, 2002 | 07:34 PM
crxjdmsir's Avatar
You rule!! That helps alot. Thank you
Old Sep 21, 2002 | 09:46 PM
civbeater90's Avatar
just some helpful hints.use a torch if you can it speeds things up a lot.also if you have a high speed grinder get a wire wheel i thinkit;s a 3 inch.clean the whole thing out.do the same on the pin.to get teh metal halves out of the arms use a screwdriver and hammer and go down about 1/2 inch deep all the way on both sides,then usually they are ready to come out.take your time.once it's all cleaned up i just use a big vise and a freind to press them in and use plenty of grease.to put in the pins,i set the arm on the gorund push the pin in slightly then stand on it.with enough grease it wil just slide in.it will strighten it self out when it is bolted on to the car.
Old Sep 23, 2002 | 06:58 PM
crxjdmsir's Avatar
Turns out the bushings were boxed wrong. Went back to where I bought them and the correct set will be here tommorrow. Thanks again, you guys did help alot.
Old May 1, 2003 | 07:43 AM
ragejed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jc836 &raquo;</TD></TR><TR><TD CLASS="quote">Have them on my 89 CRX Si and it is not a lot of fun putting them in. Actually, my fabricator (ITA builder) did it and he had to take the arms off the car to remove the old bushings. You have to get the center pin out and clean off all the rubber stuck to it and cut the rubber out of the shell. Once everything is clean the new bushings slide in without a lot of fanfare. A press would be nice. If you are going this far, get a set for the lower control arms too as this will definitely tighten things up. Don't do any others until you are certain that you need them-the front can bind on road courses-so rubber is better there except for the radius rods and sway bars.
Good luck</TD></TR></TABLE>
Anyone verify this???
Old May 2, 2003 | 07:22 AM
BERT-O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdMB16Ahatch &raquo;</TD></TR><TR><TD CLASS="quote">hey look wut i found after searching once... </TD></TR></TABLE>
aimbot
Jan 4, 2008 04:02 AM
1xfastxhatch
Suspension & Brakes
Dec 19, 2007 07:48 AM
WVTURBOCRX
19
Oct 25, 2005 10:00 AM
Vinceg99
Nov 3, 2002 07:20 AM
