Suspension & Brakes Theory, alignment, spring rates....
Replacing trailing arm bushings
Old Nov 13, 2010 | 09:06 AM
lxdriver's Avatar
Default Replacing trailing arm bushings
I need to replace the trailing arm bushings because it messing up my tires but I don't have the bushing extractor, is anyone here renting it? I'll return it back to u when I'm done with it.
I know I can do it without the extractor but I would have to take the whole trailing arm off the car and it seem like a big hassle, but I'll keep that method as a last resort. PM if u have the bushing extractor for rent.
Old Nov 14, 2010 | 04:35 PM
joss731's Avatar
Default Re: Replacing trailing arm bushings
I have the tool I hope ur in ny...516 303 5573 lmk
Old Nov 16, 2010 | 12:11 AM
Mordiiax's Avatar
Not to hard to do without any special tools
http://www.youtube.com/watch?v=hPTDzrxqoOo
and i did it myself also:
http://www.youtube.com/watch?v=7329Kw5xzNU
But with the Pwd:JDM bushings.
Old Nov 16, 2010 | 09:21 AM
lxdriver's Avatar
No man, I'm in cali but thanks for letting me know
Yeah I've seen this video before but do I have to remove the whole trailing arm off the car or is it possible to do it with it still attached to it? And if it has to be removed, how would I go about it in regards to the e-brake line, and just a heads up, my car is a 6th gen and I saw that urs is a 5th gen so I'm not sure if that might differ a lil bit
Old Nov 16, 2010 | 10:49 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Just unbolt it all. Leave the brake line attached to the caliper. I did this myself awhile back when I had all the bushings replaced on my suspension. It's a little time consuming with all the parts that have to come off of the trailing arm, and it's cumbersome as hell, but it can be done.
Old Nov 16, 2010 | 09:00 PM
Mordiiax's Avatar
^ What he said.
As seen in my own little film i hade a strong friend to assist me and stop the motion of the trailing arm when hitting the bushing with a hammer.
Just be careful not to snap the bolts
Old Nov 17, 2010 | 12:03 AM
lxdriver's Avatar
Aight I'll try it out like that. What about which bushing would be better to use? OEM type or energysuspension one in which the metal center piece must be used? Help me out please cuz I wanna do this upgrade as soon as possible
energysuspension's bushing is like $50 less for "better performance"
Old Nov 17, 2010 | 06:32 AM
Community Builder
DO NOT use polyurethane for trailing arm bushings. This is even more critical than the other suspension bushings. The RTA bushings MUST be able to flex to a certain extent to allow the proper suspension range of motion due to the design of the rear suspension geometry. Poly RTA bushings do not allow this range of motion and will bind up and cause handling issues.
Rubber and spherical RTA bushings are the only ones that allow the proper range of motion, but spherical is not suitable for street use (they will wear out very quickly if used for normal daily driving).
Old Nov 17, 2010 | 09:03 AM
efvader's Avatar
was just thinking about doing this on my new gsr.
have these mugen ones sitting in the box for years that i should probably do something with
http://www.kingmotorsports.com/p-262...piece-set.aspx
Old Nov 17, 2010 | 09:47 AM
Jockone's Avatar
I had urethane energy suspension bushings in my CRX for 6 years with no problems and in wifes civic and in my civic for about 4 years have also installed many sets for others and nobody I know of has had a problem.
I would personally go with ES urethane ones,it is easy to do and you dont have to remove the whole trailing arm.The worst part is cutting out the old rubber bushing.
Old Nov 17, 2010 | 04:08 PM
Community Builder
Might as well, no need to waste $140, although people have reported they look exactly the same as OEM.
Old Nov 23, 2010 | 09:39 AM
efvader's Avatar
yeah so i pulled them out of the box last night and they do look oemish. anyone have any feedback on them? i got them years ago somewhere..
xlonelydrifterx
Southern California
Apr 27, 2016 07:25 AM
TOO MUCH TORQUE
Northern California (Sales)
Jan 29, 2016 06:15 PM
DoubleEx
Honda Civic (2001 - 2005)
11
Feb 21, 2010 05:51 PM
Jaminak
23
Jun 6, 2002 12:57 PM
