power steering confusion
hey guys, i recently swapped a 4th gen motor (F22B DOHC) into my 5th gen for my turbo build. however, i can not figure out what i need to make the power steering work. for instance, my 5th gen pump wont fit on the 4th gen bracket on the engine, but my 5th gen power steering line does not fit the 4th gen pump, which fits the engine. anyone with insight please chime in. I know that i have to be missing something or having a massive brain fart because i know that people swap jdm engines into 5th gens all the time and retain power steering. If i can not figure this out i am likely just going to pull it all and loop my lines, but i really dont want to be without power steering in a 5th gen unless absolutely necessary. thanks for the help.
Brandon
Brandon
should i have any troubles getting the 5th gen bracket to bolt to the 4th gen block? Im pretty sure the blocks are the same but it cant hurt to ask. also, i am about to buy a bracket right now from a forum...does the 5th gen bracket not have the arm that comes out on most honda PS brackets (atleast 4gen preludes and accords)? The one im looking at does not and i am questioning it.
