quick front swaybar question(frame related)
so i switched my front sway bar, (the curvy one).
problem is, one of the two driversiide bolts(inthe bracket) that holds it to the frame snapped.
so what i'm wondering is, will this cause any problems, will it put strain on the one bolt and eventually snap or break under reasonable daily driving conditions?
my guess it will snap over time and bracket at bend easily, losing the bushing then will cause lots a clanks and bangs
so how do i fix this?
on the driverside when u mount the bar the bolt thats snapped is still in the mounting pplace on the chassis n not the bracket itself
cant get it out. ne suggestions?
no this is not the end links its the bracket holding the bushing that bolts into the frame
the soL that could
Sep 12, 2011 06:19 AM
