koni str.t and eibach sportsline??
ive got a 95 accord that i used str.t's on the front, and with a small drop (about 1.5"), the struts blew out and now leak oil everywhere and ride worse than the stock struts...they're actually designed to be used just as a factory replacement strut. just my .02...
Hard to say who/whats at fault, I have OEM shocks with H&R sports spring, rear is drop about 1.5 and front is slammed cause i cut the springs, tires are tucked under fender and ive been riding like that for awhile now, no leak or no blown, It's just too bouncy so i wanna get new springs and shocks.
and what are the spring rates on the nuespeed race?
as for the h&r neu race springs and str.t's. it works but it's going to be light in the back. the sport really is the shock you should be using on race springs
actually they are a sport set on soft. if you have blown one at that height, which is a bit hard to believe but you may have gotten a bad shock, call koni and warranty them. my other guess on blowing them is you have soft rates and slammed the car into the ground a few times. this will blow any shock if you just beat the weight of your car into the shock body.
smiko0124
20
Dec 9, 2003 09:00 PM
DrunkNRacer
Oct 24, 2003 11:02 PM
