My Del Sol is a GROSS POLLUTER!! Need Help!!
So I just did the smog and it came out to be a Gross Polluter. The tech said it might be the cat converter. Here are my readings:
15mph:
HC: Max 92 / Measured 226
CO: Max 0.55 / Measured 0.41
NOx: Max 716 / Measured 3062
25mph:
HC: Max 57 / Measured 203
CO: Max 0.54 / Measured 0.88
Nox: Max 764 / Measured 2231
The HC and NOx is WAY to high!!!! He told me it could be the Cat. I have a D16z6, AEM intake, and aftermarket ebay headers. Before i went to get it smogged, I adjusted my timing to 16 degrees (where it should be). Can it be the Cat converter? Any suggestions would be appreciate it.
15mph:
25mph:
im in the same boat my del sol is a GP my emissions were in the 500 range and my timming was at 22
if its just the cat update this so i can know to change mine
i could be completely wrong but i think your emissions are incredibly high even for a new cat to fix this you blowing smoke or have major loss of power up hills?? it sounds like you got something else happening
I wonder what kind of spark plugs, coil and wires, he is using. If he isn't using stock such as NGK and Denso, then he is wasting our time.
Civic Racer X 7
14
May 1, 2011 09:55 AM
wakaranai
Northern California (Sales)
Jan 19, 2009 04:15 PM
