1999 Acura Integra ls/Vtec Turbo- $7500 or FT+$4500
I'm Looking To Sell
I want $5000 firm
winter is coming and car payments and insurance are way too much for a college student with a parttime job
Firm on 4500 plus the trade because that is what i owe on my loan.
Located in Mason City,IA
CALL or TEXT 641-420-2114 with any questions
1999 Acura Integra Ls/Vtec Turbo--Runs Great!
Nice, Quick yet streetable
9 psi runs off gate only
Clean Title
97,000 miles on chassis
Around 3000 miles on motor
Has Cruise
Has ABS
No A/C
No P/S
Tuned on Crome By Full Blown Motorsports - have receipt*
*I would recommend getting a re-tune because I switched Downpipes from a 2.25 to a 3"
and Will trow in a Bigger Intercooler too If you plan to get it retuned* And make some more POWA*
CEL- shift light @8100 Rpm
Launch limiter Set @ 3750 Rpm
Motor-
B18b1 W/ GSR head
Golden Eagle Vtec Conversion Kit
New Pistons-Oem
New Rings
New Timing Belt
Newer Gsr Dizzy
Newer Gsr Water Pump
New Moroso Dizzy Cap
Acl Race Rod Bearings
Arp Rod Bolts
Arp Head Studs
Gsr Cams
Gsr intake mani
Cometic Head Gasket
Skunk 2 Cam Gears
Hondata Intake Manifold Gasket
Alot of newer seals
Itr Valve cover
Itr Oil cap
Nrg Carbon fiber spark plug cover
pswjdm cam seal
Driveline-
Stock Ls trans
Stage 2 Carbon kevlar clutch
B&m Short shifter
Energy suspension Shiftlinkage Bushings
Fuel-
Walbro 255
Dsm 450's professionally cleaned and pressure tested
blox fuel pressure regulator
B&M fuel pressure gauge
Turbo setup-
Turbonectics T3/t4 .57 .60
Unknown manifold- cant think of it right now
an oil feed line- not sure on size
.63 resistor
rubber oil drain- was a An but was way too long
2.5" charge piping/some is from AEM Cold air
Small intercooler/ will give buyer a larger on when purchase
Greddy type-s BOV
Tail Gate/ running a 9 lbs spring
O'reily special air filter
Exhaust--
3" downpipe
Highflow Cat
full 3" exhaust- sounds great and is quiet
Suspension-
Tanabe Lowering Springs -Rides Great!, a little tall though
Stock Shocks
Tanabe Strut Tower Bar
Weapon R X Brace
Energy suspension Control arm bushings
Exterior--
Paint is starting to fade
Few dings and dents
Itr lip- needs painted
Itr wing
Legit window stickers :thumbsup:
Amber bumper lights
CATZ hids, white
Interior--
Mint Black Cloth
Mint Black Dash
No rips or tears
Glowshift Boost Gauge
Glowshift oil temp gauge
Pilliar pod
Spoon Sports shift ****
*Will now come with aftermarket radio will come with stock*
Oem integra floormats
The Bad--
Has a new driver side fender and since paint is faded the fender is a bit darker
has gay 14 inch wheels and shitty tires, But may have ls meshies by time of sale
has really small oil leak coming from oil return gasket on turbo
Could use a better vent system, only way it has to vent is a line running from valve cover vent to brass fitting on my air filter
Im sure there's more things im forgetting and will post them if i remember
Test Drives For serious buyers only**
here are some pics, get better ones if need be and inteiroir pics will be up soon
AT JDM CITY MEET--V
I want $5000 firm
Clean Title
Has Cruise
Has ABS
No A/C
No P/S
Motor-
B18b1 W/ GSR head
New Pistons-Oem
New Rings
New Timing Belt
Newer Gsr Dizzy
Arp Rod Bolts
Arp Head Studs
Gsr Cams
Gsr intake mani
Cometic Head Gasket
Skunk 2 Cam Gears
Alot of newer seals
Itr Valve cover
Itr Oil cap
pswjdm cam seal
Driveline-
Stock Ls trans
B&m Short shifter
Fuel-
Walbro 255
Turbo setup-
.63 resistor
Greddy type-s BOV
Exhaust--
3" downpipe
Highflow Cat
Suspension-
Stock Shocks
Weapon R X Brace
Exterior--
Few dings and dents
Itr wing
Amber bumper lights
CATZ hids, white
Interior--
Mint Black Cloth
Mint Black Dash
No rips or tears
Pilliar pod
The Bad--
AT JDM CITY MEET--V
Hey man its alright happens to the best of us, i would think about it but this is my only car and i want a nice DD that is worth about 2000-3000 to drive in the winter, would like to find a del sol, but any other civic, or integra would be alright
LSBrother87
Mar 7, 2007 06:35 PM
