96 Civic CX wont idle, surges
Car:
96 civic cx
LS swap
hondata s100
Ever since I pulled motor from my EG and put in in this Ek has been having problems. Im throwing a code 0 because every time I jump the connector CEL goes out. It will start but run like **** and it will only stay on if i hold on gas pedal even then sounds horrible, when it warm it trys to stay on bearly even then lets say I hold throttle at 1500rpm it will just jump up and down like crazy surge. I have tried: New throttle body with diff tps,map, different IACV, diff ecu, diff plugs, checked ground g101 cleaned it and checked brown wires goin to ecu they have connection, I added more chassis grounds.
Any imput is apriciated Thanks
96 civic cx
LS swap
hondata s100
Hvactechgreen
10
Aug 15, 2018 05:58 AM
pinoyboy204
Sep 2, 2005 05:23 AM
