What intake for GSR manifold on EG w/ ABS?
Old Nov 11, 2010 | 06:00 PM
Rok_Stok's Avatar
Default What intake for GSR manifold on EG w/ ABS?
Car: 1994 Civic Si ABS
Engine: JDM B18C w/ stock GSR intake manifold
I bought an aftermarket intake before the swap and have come to find out it doesn't fit because my ABS is pretty much right next to the throttle body. I put on a stock B16A intake arm and it works because the rubber can bend over the ABS brake lines. Just wondering if anybody has experienced this before.
Old Nov 11, 2010 | 08:48 PM
NotAJDMFanBoy's Avatar
Default Re: What intake for GSR manifold on EG w/ ABS?
Who has ABS? You either need to cut or bend something or find something that will work. If that means getting a couple pieces of mandrel bent piping and another coupler, do it.
Old Nov 12, 2010 | 01:59 PM
Rok_Stok's Avatar
I think I should stick with silicone and rubber intakes, like the Samco, or maybe a stock ITR, because I can't find any aluminum intake that can fit.
Old Nov 12, 2010 | 02:04 PM
00b18ek's Avatar
just pick up a type r style mani like skunk2 or something makes things so much easier
Old Nov 12, 2010 | 02:22 PM
Rok_Stok's Avatar
Yeah it's tempting because the engine picks up quite a bit when the IABs open, probably because I have a CTR intake cam. But I like the low end torque for driving around town, that's the whole reason I stuck with the gsr manifold. But yeah a skunk2 would create a lot more space and I could put on any intake I wanted.
Old Nov 12, 2010 | 02:27 PM
00b18ek's Avatar
and you get more mid range power as well
Old Nov 12, 2010 | 03:45 PM
H22AFerio's Avatar
Just put a 90 degree bend on that bastard and put it through the fire wall into the a/c box problem solved cold air intake lol jk
I ran into the same prob with me old coupe I just swapped out the brake lines for non ABS and did a line tuck.
Old Nov 12, 2010 | 08:35 PM
Rok_Stok's Avatar
Dang I really want to do an ABS delete but that's a crapload of work gathering all the non-ABS lines off of a non-ABS hatch and then...ugh, so much work.
BTW...nice cold air intake idea I was crackin dude. Signature worthy!
Old Nov 13, 2010 | 08:59 AM
H22AFerio's Avatar
lol thanks. Its not as hard as it looks. you just need to have a good 3 or 4 days to pull the engine and drop the sub frame to get to the lines. good luck with what ever you do man.
LANEVOIX
Aug 22, 2005 06:52 AM
B18C_DD
Aug 8, 2005 01:11 PM
PhiLG
Mar 6, 2005 04:05 PM
jin_gsr
Feb 28, 2005 04:08 AM
