Garrett intercooler cores leak?
Old Nov 11, 2010 | 01:16 PM
twinturboz161's Avatar
Default Garrett intercooler cores leak?
I read that garrett cores can leak on arrival, anyone have any experience with this? Where are the spots they can leak from? I am currently building endtanks on one and was curious before I go further.
Old Nov 11, 2010 | 01:52 PM
PPLH8R's Avatar
Default Re: Garrett intercooler cores leak?
I would be willing to bet that most intercoolers have small leaks from the cores and people are just not aware of it. As long as the leak is not causing a large pressure drop I doubt it would have any effect on performance.
I learned the hard way that when building liquid intercoolers it is a good idea to check for leaks after the endtanks have been welded on.
Old Nov 11, 2010 | 01:57 PM
Yeah I guess I have no way to test the core itself so I guess i'll go ahead and weld them up and go from there when I can pressurize it.
Old Nov 11, 2010 | 04:53 PM
salival's Avatar
You should be testing a water to air intercooler in two stages, one when the water tanks go on then again when the air tanks go on.
Old Nov 13, 2010 | 09:36 AM
covertperformance's Avatar
I have a recieved new garrett cores that have leaks.......dont find them till i weld on the end tanks and psi test the unit. I then weld up the leak/s in the core that i find. Distributor always offers to exchange the unit but not worth it after welding on the endtanks,etc... plus theres always the chance you can get another leaky core.
tron_
Jun 16, 2012 11:30 AM
cxVtecC1
Dec 1, 2004 07:57 AM
iwouldHITit
Jan 20, 2003 06:50 AM
DSF
Apr 22, 2002 03:39 AM
