How do you remove the 94-01 Integra coinbox?
Old Nov 11, 2010 | 12:54 PM
Outrun's Avatar
Default How do you remove the 94-01 Integra coinbox?
Trying to install some OEM foglights and I have to remove the lower dash cover. One of the screws is covered by the coinbox and the instructions simply say "remove coinbox".
Well, it's easier said than done. I feel like I might break the darn thing trying to take it off. I depressed the two upper tabs so that the coinbox will open wider but from there I dont' know what to do.
Old Nov 11, 2010 | 03:40 PM
fcm's Avatar
fcm
Old Fart
Default Re: How do you remove the 94-01 Integra coinbox?
You need to shove a tapered tip, [plastic is best but a "flat" screwdriver with tape will work] at the hinge point to spread the plastic, then you can "pop" the tray out. 94
Old Nov 11, 2010 | 04:34 PM
el crapitan's Avatar
if it's the same as a DA (i suspect it is) one side will have a slight taper on the pin. but yeah, you can just pop it out. honda abs plastic is very flexible
Old Nov 11, 2010 | 05:00 PM
Outrun's Avatar
I used a flat screwdriver and gently pried on the left side while pulling the coinbox out. The peg was slightly damaged but should still be functional.
Thanks for the tips!
KILLAB17VTEC
Jun 18, 2008 04:39 PM
giff74
Mar 19, 2005 02:09 AM
Pakman
Audio / Security / Video
Jan 27, 2003 12:09 PM
01-1293
Mar 31, 2002 08:38 PM
