Water coming out my exaust !!.
Ok i dont drive this car , i turn it on every cople of days and once a week i drive it around the nieghborhood.
today i turn it on wait till it warmed up and since i took the interior out i wanted to see how loud it was goin to be insice so i rev it to about 3000 rpms to see how it was. when i go out the car i saw some dirty water in the floor right under the exaust and the wall .
Why is this happening >?.
nah just moisture in the air that condences with heat. the longer you let it sit the more ambiant 'air' gets in there with the ability to turn into moisture. has it been getting cooler there?
so i dont have to make another thead :
im cleaning up my interior and i want to remove some of the cables but there this big back thing that covers where all the cables connect . im not sure if i should unbolt it because it loook likes it hold the shell firm . my questions is can i unbolt it fix the cables and bolt it back on ?
here is what im talking bout
Where do you spray the nos? If you spray it before the catalytic converter your o2 sensor isn't picking it up and causing this nos water to form. You're welcome for the tech.
If your talking about sometihg else please explain. thanks
What are you babbling about? They're not using nitrious, and its not water in the gas. It is simply condensation as previously stated, no need to worry.
you have gremlins in your car. you see when gremlins get sick they sometimes **** out of the tailpipe which is what you're experiencing. if you consider
The range is all possible values to get
out of the function.
−1≤ sinθ ≤1 cscθ ≥1 and cscθ ≤ −1
−1≤ cosθ ≤1 secθ ≥1 and secθ ≤ −1
−∞ ≤ tanθ ≤ ∞ −∞ ≤ cotθ ≤ ∞
you can then trick the gremlin into leaving thus saving your car
