eg/ek d-series turbo Y8 Z6 BIG LIST!~ you better get in here!
ALL PARTS LOCATED IN SOCAL..CORONA,92879
ENGINE:
Y8 shortblock, assembled, but no oil pan. see pic. $100
Z6 engine assy... details tomorrow $OLD
Z6 engine and trans details tomorrow $400
Y8 intake manifold complete (X2) $100 ea. see pic
Z6? complete intake manifold stamped p08..$old
B16A2 (99-00 Si) intake manifold, complete minus map and iacv $150 see pic
Z6 exhaust manifold/headerpipe combo $45
Z6 exhaust manifold/headerpipe combo w/ cracked manifold $25
Y8 Z6 exhaust manifold/headerpipe combo w/ shield $OLD
PO8 bare intake manifold $15
D16 Valve cover HONDA script (1) $15ea.
D16 valve cover VTEC script $25
B Series vtec v/c, cut for cam gears $20
short ram intake w/ filter $35
matrix pipe w/ AEM dryflow $45
apex intake $40
integra Ls rods w/ pistons $40
TRANS
S40 A000 trans blown diff, hole in case, w/ speed sensor $25
S20 A000 trans w/ speed sensor $40
S40 B000 Y8 trans out of wrecked car.. no speed sensor $OLD
92-95 civic clutch slave and line $20
D series shift linkage $40 ea.
D series axles $30 ea.
D series flywheels $15 ea.
WHEELS:
Hate to do it but here goes,
BNIB MUGEN MF-10 16x7 5x114.3 43 offset. brandnew, never mounted, still in the boxes and come with center caps and valve stems. bronze $2400
SUSPENSION:
$30 neuspeed rear lower tie bar see pic.
$30 integra/civic progress susp. camber correction kit front new PENDING
$40 92-95 civic rear drum setup complete
$35 92-95 civic brake master and booster w/ lines.
$30 EG Stock rear spring/shock combo
$45 EG Stock rear shock/ JAMEX spring combo
$100 EK Stock front/rear shock/ RS*R spring (blue) combo
CLUSTERS:
92 EG 266K DX No tach $35
94 EG 244K DX No tach $35
95 EG 183K EX/Si vtec w/tach $80
96 EK 206K EX w/ tach $80
ECU's:
'96 P2E LO1 $40
'96 P2E L71 $40
'98 P2E LO1 $40
'95 PO6 A02 chipped by JET $70
'95 PO6 AO2 $60
'XX PO6 AO2 $60
'95 PO6 AO2 $60
'XX PO6 LO1 chipped w/ program for MPG $70
'XX PO7 AOO $70
'XX PO7 LOO $70
'95 P28 A52 $110
$40 EK glove box out of 96 coupe, gray
$25 EK drivers power mirror, black
$25 Gray car cover civic/integra
$60 99-00 civic si EK replica front lip New
$20 Integra 94-01 clear plastic floormats
$20 92-95 civic headlight right
$20 98-01 integra clear turn signals
$30 98-01 integra type r amber trun signals OEM
$10 92-95 civic 2dr/3dr amber corner
$15 92-95 civic 2dr manual window regulator
GRAY EK Coupe carpet.. needs a good cleaning $30
99-00 headlight, needs buff $35
EK Coupe gray door panels (power) $OLD
TURBO
DSM Side mount intercoolers (3) $30 ea.
civic/crx HF/STD exhaust manifold $35
HMT set up... dsm t-25, hf/std manifold, adapter, supply/return lines, dsm bov, misc. piping $200
THE STASH
most items in pic will be for sale stay tuned.
call, text, or e-mail 951-515-0988
vago120@sbcglobal.net
ENGINE:
apex intake $40
TRANS
WHEELS:
SUSPENSION:
CLUSTERS:
ECU's:
'96 P2E LO1 $40
'96 P2E L71 $40
'98 P2E LO1 $40
'95 PO6 AO2 $60
'XX PO6 AO2 $60
'95 PO6 AO2 $60
'XX PO7 AOO $70
'XX PO7 LOO $70
'95 P28 A52 $110
TURBO
THE STASH
Hey man them Tokico Struts are good right..if so How much shipped 15417.....Lmk i need them and u take any trades for t25 an hf mani combo i got tons of ****
might have a local buyer for the shocks, let u know after sunday.
no trades right now.. try to empty the garage.
FRKWOO
Sep 29, 2009 02:48 PM
