Transmission & Drivetrain Gearboxes, Differentials, Clutches
D17a motor, 95 DX Transmission?
Old Nov 10, 2010 | 02:48 PM
sirtef9's Avatar
Default D17a motor, 95 DX Transmission?
Will it work as long as I use the 95 Clutch kit?
i don't see why not, but wanna make sure before i rip into it.
Thanks in advance.
Old Nov 10, 2010 | 06:19 PM
94EG8's Avatar
Seagull Management
Default Re: D17a motor, 95 DX Transmission?
Thanks in advance.
Clutch is the same anyway. at least as far as the disc and pressure plate, release bearing or pilot bearing might be different, I dunno. Whats all this going into? '92 - '00 D-series trannys are completely different than '01 - '05 (although I believe the bell housing bolt pattern is the same.
Old Nov 10, 2010 | 07:13 PM
sirtef9's Avatar
well its a 2001 civic lx with a bad trans, I happen to have a good 95 dx trans so though it would work, mount bolts are prolly off eh?
Old Nov 11, 2010 | 12:30 AM
Aquafina's Avatar
Cable vs rod.
Old Nov 11, 2010 | 11:12 AM
sirtef9's Avatar
Originally Posted by Aquafina
Cable vs rod.
Duh, thanks man!
Em1Coming soon
Oct 4, 2009 05:28 PM
effinnwackk
Oct 2, 2004 12:54 PM
