solution for removing anodize?
Old Nov 10, 2010 | 02:25 PM
RACEPAK's Avatar
Default solution for removing anodize?
hi,
i'm looking for a quick way to remove anodizing from aluminum parts.
is there any solution that i can dip the parts and have them completly cleaned?
thanks
Old Nov 10, 2010 | 02:42 PM
aerofurysc's Avatar
Default Re: solution for removing anodize?
Oven Cleaner, leave on for 2-3 minutes, agitate with a toothbrush and rinse with water. It only takes 1 or 2 applications. Be cautious though, if you leave the cleaner on too long it will turn the part black.
Old Nov 10, 2010 | 03:52 PM
-Crash-'s Avatar
Also keep in mind that anodize penetrates into the metal, so for example if the part has an anodize thickness of 2mil, there will be 1mil into the metal and 1mil on top of it. So if it does not all come off with the above mentioned process then a little sanding will get the rest.
Old Nov 10, 2010 | 08:19 PM
siblues's Avatar
Oven cleaner will remove any of the anodizing I have ever tried removing.Just leave it on a few minutes and scrub off the part will be bare aluminum when done..
Old Nov 11, 2010 | 10:43 AM
HickamHatch's Avatar
Purple Cleaner or Purple Power will also work. Leave the parts in the cleaner for 15 minutes and scrub off... sometimes the anodizing is harder so it will need to soak longer. Rince off with water and bam... Use a little wire brush
Old Nov 11, 2010 | 01:18 PM
Colin's Avatar
We used drain cleaner for a few parts, worked like a charm.
http://www.flickr.com/photos/clen/3718885115/
http://www.flickr.com/photos/clen/3719700102/
http://www.flickr.com/photos/clen/3718889899/
http://www.flickr.com/photos/clen/3718890699/
http://www.flickr.com/photos/clen/3719705776/
Some light sanding took off the leftover lettering.
IBriaIN
Feb 23, 2011 10:09 AM
gizzmo222
Detailing
Jul 8, 2010 10:06 AM
rasinhell
Paint and Body
Feb 14, 2008 06:59 PM
aesthetics82
34
May 10, 2004 07:52 PM
IdotheSHOCKER
Jun 2, 2002 12:52 AM
