94-95 GSR longblock $500 FIRM FRESNO, CA
I have a 94-95 GSR longblock for sale but the head and the block are apart. willing to part out or buy as whole for $500. Prices are FIRM not in a rush to sell.
94 GSR Head- $200- firm
-the head is pretty much stock except for the portflow dual valve springs with stock retainers.
-does not come with distr., injectors, or fuel rail but all the sensors.
-95 GSR Block- $400 Firm
-the block is pretty much stock except it has turbo wasco piston which are 9:0:1 compression ratio.
-block will come with tap oil pan and it is a complete block.
-BAD: walls are rusted because its been sitting for about 1yr now. If you can get the walls cleaned then the block is good to go. Was on a running car before the motor was parted.
as you can see the top is the only part that is rusted on all four cyclinders
The reason why the head is not on the block is because I had a 94 GSR motor which threw a rod and I bought this block with the turbo piston already to install. I have no other car to put this motor in so now its up for sale. Not in a hurry to sale so prices are FIRM $500. call or txt 559-977-9848 for more info. parts sold as is and must be picked up. Located in FRESNO, CA
bump took the block to the machine shop and the guy just told me to wipe the top of the walls with wd40 and an emily wipe and the block should be fine but i still need to get rid of it...bump again for a good price.
egb18c5
Northeast (Sales)
Oct 5, 2007 06:03 AM
