Quick OBD2 LS valve cover question
I just put a OBD2 LS valve cover on my da with a b18a1 motor. I noticed that there is a hole in the middle of the back of the valve cover where, on a crv or obd2 integra, another breather line connects. I cont have another line to connect to it so idk what to do. When the car is running, air is puffing out of the hole. should i plug it or put a breather filter on it? thanks guys
Your pcv systems are setup differently on obd-1 cars then obd-2. On obd-1 cars the pcv valve is in the intake manifold and on the obd-2 it's on the valve cover. Just extend the hose that went to your stock pcv and put it in the valve cover.
SCIVIC94
May 11, 2006 08:25 PM
