1991 accord timing belt
Old Nov 9, 2010 | 04:57 PM
kc2mrg's Avatar
Default 1991 accord timing belt
i just got this accord its got 203k on it and i was gonna put a new timing belt on it, ive nvr done a timing belt before (im a bmw tech, we have chains), from what i can tell it has what looks like 2 belts, one for cams and one for oil pump i think? and is it worth getting the tensioner pulleys and both belts, and should i replace the water pump also, or no, i can get the for both belts, tensioners and water pump for $80, and how is it tensioned? hydraulic or mechanical spring
Old Nov 9, 2010 | 05:30 PM
TouringAccord's Avatar
H-T Order of Merit
Default Re: 1991 accord timing belt
you should take a look at the timing belt how-to located in the FAQ sticky, that will probably answer all your questions plus some.
Old Nov 10, 2010 | 09:05 AM
nus_dogg's Avatar
Mechanical Spring tension.
ek02
17
Sep 23, 2018 09:08 PM
Gravymeister
26
Feb 21, 2014 04:28 PM
Edward44
Jan 28, 2006 12:11 PM
teler86
Jul 26, 2005 04:22 PM
