using a timing gun on a zc..
Old Sep 21, 2002 | 11:47 AM
zcivic91's Avatar
Default using a timing gun on a zc..
i just got a timing gun to retard my timing some for the n2o.
when i put the light on the crank pulley i can see the 3 marks and to the right is another makr...i guess thats the tdc mark. i tried setting my timing to the middle mark of the three. but if i give it some gas the marks move to the right the higher i rev the motor...wats wrong?? am i supposed to disconnect sumtin?
im using a basic timing gun..
Old Sep 21, 2002 | 12:09 PM
zcivic91's Avatar
Default Re: using a timing gun on a zc.. (Matthew)
ok at 800 idle i set it to the right line of the three...that should be 16 btdc right??
and yea i jumped the blue connector but it doesnt really do anything..
i just dont want to have my timing advanced AT ALL so i can run the n2o safely..
Old Sep 21, 2002 | 02:35 PM
Malgerus's Avatar
Default Re: using a timing gun on a zc.. (zcivic91)
I believe bridging the connector stops the computer from messing with th etiming at idle.
Old Sep 21, 2002 | 08:41 PM
1990hondaHF's Avatar
I knew I was missing something...
make sure you are jumping the proper connection while setting your timing, i believe its the free blue plug by your ecu on the 91's.
-matt
...I'm not sure I understand what you mean? I know what "jumping" means...like a computer's motherboard right? If I understand this, when I do that it really won't matter what the idle is because the ECU can't control timing anymore? Also, is this blue plug on the ECU?
Also what is my car won't idle any lower then about 900 RPMs? Mine is a 1990 HF/ZC if that help, with a PM7 ECU. Thanks!
prodjay10
May 6, 2016 10:43 AM
92ehatch
Jul 28, 2007 05:40 PM
sageuvagony
Apr 5, 2007 05:47 AM
bazookatooth
Apr 23, 2005 11:56 PM
slowd16z6
Mar 13, 2004 02:20 PM
