f22b in 94 honda accord ex will not start
Old Nov 9, 2010 | 10:29 AM
dohiot's Avatar
Default f22b in 94 honda accord ex will not start
i have a 94 honda accord ex its been sitting for a year just through a f22b in it and it will not start has gas has spark it cranks over really slow
Old Nov 10, 2010 | 11:55 AM
sgraham01's Avatar
Default Re: f22b in 94 honda accord ex will not start
if you know the engine is good and you have spark, it could be a fuel problem since the pump sat idle for a year. fuel pumps can stick when they sit that long. did you mean it has fuel in the tank, or it has fuel pressure? make sure the pump is running.
Old Nov 10, 2010 | 01:52 PM
HYPROPULSION_R's Avatar
did you replace or charge the battery? After sitting a year i'm shocked the battery would still be alive.
Old Nov 10, 2010 | 08:07 PM
holmesnmanny's Avatar
Ya, anytime you have a car sitting you always disconnect the battery. It actually draws juice when it's not even running or using any accessories.
Old Nov 11, 2010 | 08:35 AM
rhdins's Avatar
If you mean that you have fuel in the tank, and not that you're getting fuel in the cylinders, then you probably have a ground that's not connected somewhere. I had the same problem. I was getting spark, it was turning over, but no fuel. Found a ground that wasn't connected, hooked it up and it's been running great ever since.
Old Nov 12, 2010 | 08:06 AM
dohiot's Avatar
i meant it has fuel pressure and gas in the tank.... the fuel pump is kicking on... and i removed the battery from it as soon as it broke down...all the grounds r hooked up....but i got it to start it just running kind of funny now. at idle it dies down almost to 0....
Old Nov 16, 2010 | 12:14 AM
could be the fuel filter picked up a bunch of corroded pieces in the tank and is clogged.
Stockcb793
Nov 28, 2015 04:55 PM
dynasty3408
Apr 9, 2013 08:03 AM
Mtwostwo
Sep 3, 2010 01:25 PM
Tonette
Jul 31, 2010 06:56 PM
FREQUENCY 24.7
Jun 8, 2010 11:10 PM
