ac/heater smells????
Old Nov 9, 2010 | 10:27 AM
SLIMBEN's Avatar
Default ac/heater smells????
i have a 94/95 accord when i turn on the ac/heat it smells funny? can anyone help me fix this! thanks
Old Nov 9, 2010 | 11:06 AM
NOFX's Avatar
H-T White Ops
Default Re: ac/heater smells????
You'll get better results if you describe how it smells.
I had a '93 Accord that would get an old, musty smell when I turned the air on. It wasn't a huge concern, but later my blower motor went out so while I was in there I looked around for anything that might cause the funny smell. Turns out the smell was just 16 years of dust collected on the blower fan.
Old Nov 12, 2010 | 07:49 AM
SLIMBEN's Avatar
kinda smells like outside dride dirt????
Old Nov 12, 2010 | 11:20 AM
NOFX's Avatar
H-T White Ops
That's probably pretty much what it is.
I don't know how bad it is to get to the blower fan/motor for a 5G Accord, but the 4G one sucked ***. The blower assembly was just a tiny bit bigger than the hole (glovebox). Plus the blower assembly had to sort of tumble out backwards to get it out of the dash. It was a huge pain to get it back in place too.
But I had no air at all and the weather had been above 100 so I was ready to get it done.
Old Nov 12, 2010 | 11:33 AM
TheMuffinMan's Avatar
He knows where you live!
For the 5th gen, it's 3 bolts or screws on the bottom behind the glovebox.
Take out the floor mats and fold back the carpet and you should have enough room to remove it.
Unplug the wire and undo the three bolts (one is hard to reach towards firewall) and then swing it out and clean it out.
There also is a DIY where someone used some type of anti-microbial/bacteria spray and sprayed it into the AC vents several times over a few days to kill off any bacteria causing a smell.
Old Nov 12, 2010 | 12:03 PM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/honda-accord-1990-2002-2/diy-c-cooling-system-2793650/
Old Nov 12, 2010 | 04:08 PM
NOFX's Avatar
H-T White Ops
The deodorizers should work on most cars, but on my Accord it didn't last long. It just masked it until the fan was washed in the sink. Hope it works out for you though.
Old Nov 13, 2010 | 04:45 AM
Originally Posted by HondaPartsHero
KNEW I saw that somewhere
Old Nov 13, 2010 | 11:30 AM
HonBeer's Avatar
dride?
Old Nov 14, 2010 | 07:48 AM
2001B18C1GS-R's Avatar
i have this same problem in my 99 accord and my blower gets louder the higher i turn it up any ideas any diy to replacing it
Old Nov 14, 2010 | 12:31 PM
NOFX's Avatar
H-T White Ops
Originally Posted by HonBeer
dride?
Dried.
In my '93 Accord the blower would get louder on the higher settings. I'd have to keep it low just to keep it from making this weird sound.
Once I replaced the motor it all worked well. I replaced the resistor first (it fried) only to have it fry again and also have to replace the motor.
Old Nov 14, 2010 | 04:32 PM
any diy or write up on replacing a blower motor lmk thanks
Old Nov 23, 2010 | 11:45 PM
SLIMBEN's Avatar
thanks all for ur help....
cooxen77
Jun 24, 2019 12:30 PM
DebbieAT10
Sep 4, 2017 10:45 AM
hall97civic
Jan 3, 2015 10:04 AM
Dev1996
Aug 16, 2014 10:57 AM
marsulad
Honda S2000
Aug 23, 2012 12:59 PM
