confused on axels
Old Sep 21, 2002 | 11:41 AM
Na-Spirit's Avatar
Default confused on axels
yah i dont know what side my axels go on...obviously im dumb but yah..which side does the abs axel go on..or which side does the axel with the ridges on it go on..and its a 90 integra just in case that makes a difference.
thanks
Old Sep 21, 2002 | 12:19 PM
ILOVEGIRLS's Avatar
Default Re: confused on axels (mugenknockoff)
the abs rings goes on the side of the hub.
Old Sep 21, 2002 | 01:44 PM
Na-Spirit's Avatar
Default Re: confused on axels (ILOVEGIRLS)
but which side does the abs axel go on...the left or the right...maybe my trans is just screwed..shaking makes no sense
Old Sep 21, 2002 | 02:05 PM
Mr. Softee's Avatar
Hmm... one should only be the right length for one side.
Old Sep 21, 2002 | 03:01 PM
Na-Spirit's Avatar
Default Re: confused on axels (94goldjungsr)
well i guess i have them on right then...but why would my car start shaking right after i put them on....it does it only when i accelerate with a little bit of power
Old Sep 21, 2002 | 05:56 PM
ILOVEGIRLS's Avatar
both sides have the abs rings. are u sure your axles are in tight, the axles nut is tight? the driver side connects to a half shaft which im sure you can tell..the passenger side connects straight to the tranny if that helps. are these rebuilt axles...a poor rebuild may be the issue.
OOOtony
Mar 4, 2009 06:38 AM
cowboys22cardinals22
10
Mar 18, 2008 05:25 AM
SimplyTron
Nov 5, 2006 12:30 PM
evolve
Nov 5, 2004 11:12 AM
charjacq
Mar 2, 2003 09:21 AM
