Compression ratios between b16 head and gsr
Old Nov 8, 2010 | 02:03 PM
boostedb20ek's Avatar
Default Compression ratios between b16 head and gsr
I am building a b20 wit gsr head. I have some wiseco pistons from my turbo build that I would like to use with this build. 84mm with the b20 block, pistons said 8:5:1 w/o vtec head and 9:5:1 with b16 head. I know the compression changes a little with the gsr head and smaller combustion chamber,can anyone tell me about what it should b around with an oem hg. And I plan on spraying it, first time to mess around with nitrous, would this comp ratio b good with spray or should I go higher? Thanks ( fully built head, pro2 cams, built bottom end, stock sleeves)
Old Nov 9, 2010 | 03:46 AM
Default Re: Compression ratios between b16 head and gsr
Bumps
acurab20b
May 16, 2010 07:38 AM
hYbRid_Eg6
Dec 20, 2009 07:01 PM
97-crv-owner
Sep 18, 2008 07:42 PM
L33TsAbabyEater
Sep 11, 2006 06:53 PM
Tyson Ballou
Dec 26, 2001 06:17 PM
