Suspension & Brakes Theory, alignment, spring rates....
Need alignment or tire problem?
Old Nov 8, 2010 | 02:02 PM
netfreak's Avatar
Default Need alignment or tire problem?
So... I moved my rear tires (195/60/14's on OEM CRX wheels) to the front and moved the fronts to the rear (same tire size, but were on steelies). Suddenly I've got bad torque steer and my steering wheel pretty much constantly shakes. What is the likelyhood an alignment will help with this? Checked tire pressure, wear on tires is identical and very minimal. Had an alignment done about 4-5 months ago with the steelies on the front.
Old Nov 8, 2010 | 03:03 PM
Mattdg67's Avatar
Default Re: Need alignment or tire problem?
Have your wheels balanced, and if that dose not correct it check your bushings and have an alignment done.
Old Nov 8, 2010 | 03:35 PM
netfreak's Avatar
Well I found the problem. SOMEHOW these tires are different brands. I don't know if either a) I was drunk then I worked on the car they came from, or b) I realized it at the time but didn't care because they were going on the rear. Damnit...
Andrew760
Jul 19, 2011 02:25 AM
GSRkrod
Honda S2000
17
Oct 13, 2009 05:15 PM
rktechteg
Sep 6, 2008 04:20 PM
wpsadmin
Jul 5, 2005 12:22 PM
DI9ITAL
May 8, 2003 11:33 AM
