H22a1 build
I plan to build my prelude, i got a H22a1 backed with a 5 speed lsd.
Hondata s300 is the first move
Whats the best set of vtec cams for my car. I plan to drive it everyday after installation....and cam gears.
Next i wanna get a ITB setup
Then valves, spring, retainers...
Any suggestions???????
H22 skunk2 stage 3 cams would add alot of power, how ever you will need duel valve springs and aftermarket retainers, and probably aftermarket valve set.
And You will need to get it dyno tuned after installation IF you wanna make the most power
I wouldnt suggest stage 3's for a daily driver or unless you have a built bottom end. I think a stag 2 skunk2 or brian crower stage 2 cams both require vulave springs and retainers for this. Cam gears go with skunk2 comes with a nice timming belt and away you go.
hyrolnpimp
24
Mar 24, 2004 12:52 PM
Mr Hybrid
Mar 16, 2003 12:04 PM
b16powwer
Oct 24, 2002 06:43 AM
