ground issue,,checked the major spots
I requested a short story for a title.
Im having a serious ground issue with my car and im having a great amount of trouble trying to find the cause, I have checked the ground on the transmission and also the ground on the thermostat housing. I even added another ground on the block to the fram and replaced and cleaned the battery cables and plugs.
Im still having this issue tho, here is a pic of what my headlights are doing...HALP!!!
If it is dim on both high and low beams it is the pass. side head light ground.
Have you checked/redone the stock chassis ground, under the batt.??? 94
yaits dim on both high and low beams. Where would the pass side headlight beam be located exactly.
And ya the main chassis ground under the battery has been redone but is kinda haggard, i was gettin ready to go out and check that out right now
bigballer8526
May 9, 2017 05:59 PM
Nicholas Bailey
May 13, 2016 05:04 PM
QuickStyle
May 26, 2007 03:57 PM
