Ignition troubles. Lil bit of help?
Old Nov 7, 2010 | 08:12 PM
joeybl1987's Avatar
Default Ignition troubles. Lil bit of help?
ok so i have a 90 crx. B18a1 swap. well when they did the swap they changed everything over from the integra. even the gauges. well they also did a push button ignition. i have to turn the key to the first click and then push the button and it cranks. well if u turn it to the 2nd click the heat/fan comes on but will not start. i was able to turn to first click and then just barely turn it farther and the heat would work. well that doesnt work now. so in other words im riding around in 30 degree weather with no heat. i was thinkin maybe i could mess with the ignition wiring and get the heat and all to turn on on the first click along with it being able to start.
im really confused on what to do about it.
sorry if i explained that confusing.
please. any suggestions?
Old Nov 8, 2010 | 03:47 AM
Bigdavebrooks's Avatar
Default Re: Ignition troubles. Lil bit of help?
find the power wire for your heat and run it to a good power supply also make sure it has a good ground
Tank_EM2
Honda Civic (2001 - 2005)
Aug 22, 2014 08:31 AM
bfpicard
Mar 17, 2014 07:44 AM
loki2010
Dec 30, 2010 07:18 AM
94HondaAccordEX
Feb 9, 2007 08:59 PM
LisaCivic
Sep 10, 2005 06:10 PM
