d16z6 swap info 90 ef si needed...
Old Nov 7, 2010 | 06:34 PM
tyked15's Avatar
Default d16z6 swap info 90 ef si needed...
ok so im lookin to swap in a d16z6 into my 90 ef si hatch an i looked everywhere on the web for info on what i need an couldnt come across any usefull infoso i need some help...help me out honda-tech
Old Nov 7, 2010 | 07:01 PM
Slippery-Worm's Avatar
Default Re: d16z6 swap info 90 ef si needed...
Wiring harness with OBD-1 conversion, D16Z6 engine, P28 ECU... Thats pretty much it man. Use your same trans, mounts, linkage. It's pretty strait forward... anyone else is free to chime in
Old Nov 7, 2010 | 07:13 PM
tyked15's Avatar
what arhness the z6 harnessor my d16a6 harness that the only part im stuck on
Old Nov 7, 2010 | 08:18 PM
macef9's Avatar
some one help this guy! i dont know!!!!
Old Nov 8, 2010 | 04:01 AM
24TEN's Avatar
PHANTOM MENACE
The motor goes in the same way as your existing motor provided that you reuse your driver's side motor mount AND bracket. Reuse your existing harness, you may need to extend some wires or extend some vacuum lines (I say this specifically for the MAP sensor and purge solenoid, it's up to you if you want to keep those sensors mounted on the firewall as is OR if you want to utilize the ones that mount to the Z6 manifold/throttle body). You will definitely want to replace the fan switch plug (and extend if needed) to the newer style unless you want to tap the block to use the older style fan switch. Use a jumper harness for the ECU and it should have pig tails for VTEC related plugs. That should be about it.
Old Nov 8, 2010 | 10:14 AM
julyef8's Avatar
Don't forget to ad a 4 wire o2 sensor for vtec. I just put a z6 in my hf converted it to obd1 runs good!!! Good luck bro
Old Nov 8, 2010 | 11:07 AM
mkriebs's Avatar
Convenient... I am looking to swap a Vtec head on, and have a line on the head and ECM, no problems. But, do I need a harness to swap it over to OBD1? Seems like some contradiction in this thread, or I am severely misunderstanding everything.
Is it a matter of just wiring in the Vtec to the existing harness? That would be easy.
Old Nov 8, 2010 | 11:40 AM
HondaPartsHero's Avatar
Technical Hero
Use your Si harness and add or adapt the following:
-OBD0-OBD1 ECU adapter harness with P28 ECU
-OBD0-OBD1 distributor adapter harness
-rewire fan switch from the back of the block to the thermostat housing
-use your obd0 injectors and keep the resistor box
-run wiring for 4 wire O2, VTEC solenoid, and VTEC pressure switch from each sensor the ECU connector
-use the mount on your engine's (D16A6) driver side on the Z6
-use the MAP sensor on your throttle body or the one on the firewall
Old Nov 8, 2010 | 11:49 AM
96_civic_dx_b16's Avatar
this is how to do it. dont worry it isnt as hard as it seams. rewiring a dx model is alot harder! good luck
Old Nov 8, 2010 | 12:47 PM
tyked15's Avatar
yea i wired my 4 four ef bomb for a a6 swap 2 years ago
Old Nov 8, 2010 | 01:07 PM
tyked15's Avatar
ok so my harnss with obd1 conversion harness wire up vtec an o2 wire an ill be set
Old Nov 8, 2010 | 03:34 PM
uboostivtec's Avatar
cakeee.. easy jus google image vtec wiring, and there will be diagrams for ya showing where to hook up vtec and o2... im pretty sure for obd0 and obd1
Old Nov 8, 2010 | 03:43 PM
mkriebs's Avatar
Noob question alert... can't run Vtec without being OBD1, can you?
Old Nov 8, 2010 | 03:52 PM
wow yea u can
Old Nov 8, 2010 | 03:53 PM
got pw0?
Old Nov 8, 2010 | 03:55 PM
and obd0 pr3 i think.. theres also ob1 pr3 tho
Old Nov 8, 2010 | 03:58 PM
mkriebs's Avatar
Ahh fml. Back to the research boards. I am SO new to honda stuff guys. What I come from, nothing is very interchangeable. Sorry for the stupid question.
Old Nov 8, 2010 | 04:01 PM
its cool man only way to learn is to ask
mkriebs's Avatar
Whats PW0 and PR3? ECU codes?
Old Nov 8, 2010 | 04:06 PM
lol yup
Old Nov 8, 2010 | 04:07 PM
mkriebs's Avatar
Alright, I am not sure. Haven't bought the Vtec ECU yet. Just know its set back for me.
Old Nov 8, 2010 | 05:36 PM
Technical Hero
You can And I did run the pr3 for a while. But for the best just get the p28. The pr3 and pwo will both look for a second 02 and knock sensor both of which the z6 doesnt have
corey94hatchsi
Feb 3, 2014 07:20 PM
Bipolarcivic
Jun 23, 2013 02:09 PM
GinsterVRT
17
Oct 18, 2010 08:13 PM
mamaboy
19
Jan 23, 2004 06:43 AM
