Front Shock Knock, Sort Of
Old Nov 7, 2010 | 04:26 PM
mrk78's Avatar
Default Front Shock Knock, Sort Of
The shock collar on my right front is sticking up about 1/8" past the top of the rubber bushing causing it to hit the bottom of the big mounting washer. Per attached diagram the top of #14 is hitting the bottom of #6. Stupidly when I put stuff back together I didn't replace the two rubber bushings (#7). If these are worn out would it cause the collar to stick out too far - bushings over compressed or too loose? The collar was centered in between the rubber pieces when I assembled it but has moved somehow over the past few days. Not sure what is supposed to keep it in place, maybe just a tight fit? My plan is to replace both #7's and #10. Does that sound right?
Old Nov 8, 2010 | 05:15 AM
integra15's Avatar
Default Re: Front Shock Knock, Sort Of
That doesn't sound right. I have assembled many front shock assemblies on Hondas before and bever had any issues with play in them. Are you sure you assembled them with he proper torque specs and procedures? Is the mounting nut #16 on tight?
Old Nov 8, 2010 | 10:02 AM
mrk78's Avatar
Yeah, I torqued everything exactly as shown in Helms. It's worse when it's really cold which also leads me to believe the rubber bushings are toast. They aren't expensive so I guess I will replace them and see if it helps.
Old Nov 19, 2010 | 05:50 AM
mrk78's Avatar
Replaced the bushings, no more knocking. The old ones were clearly not OE bushings. They were about 1/4" shorter than the new ones allowing collar-washer contact. Now the only noise in the front end is the radius rod bushings. Maybe santa will bring me some new radius rods
Old Nov 19, 2010 | 06:11 AM
godslayer's Avatar
Good to hear that you were able to eliminate some irritating clunks from the Prelude!
Bushings compress over time and new ones very well could be a good 1/4 thicker than your old used ones. I just went through that with my valve cover seals and I'm sure I'll go through it again when I replace my 100,000 mile suspension this winter. Always replace worn bushings if it's convenient.
MilanoLude
Apr 20, 2006 06:36 AM
fe519
Oct 13, 2004 12:05 PM
Jeff99Base
Sep 13, 2004 04:30 PM
AmeenR
Jul 13, 2002 12:39 PM
thatpreludeguy
Aug 13, 2001 12:19 PM
