Suspension & Brakes Theory, alignment, spring rates....
96 ek oem suspension questions
Old Nov 7, 2010 | 03:35 PM
jakop92's Avatar
Default 96 ek oem suspension questions
1) With the rear shocks, how do you tell which one goes on which side? I thought it was supposed to have a taper to it but I can't see it.. and I mixed up the shocks because I didn't label them.
2) Can someone explain this step for re-assembly: Align the bottom of damper spring and
spring tower seat to the alignment tab as shown (60degrees +/- 3 degrees)? I don't quite understand it.
3) Are there any stamped markings on the springs? To distinguish the springs.. I know the longer ones go up front.. but I want to make sure all the springs are right length (bought full oem susp used).
Old Nov 7, 2010 | 08:38 PM
jakop92's Avatar
Default Re: 96 ek oem suspension questions
Anyone?
Here is the pic relating to question #2:
Old Nov 7, 2010 | 08:58 PM
92civiceg9gsr's Avatar
Just make sure you turn the shock hats correctly with the lower nut on the shock facing the front. There isnt a left or right.
Old Nov 8, 2010 | 10:46 AM
98civdx's Avatar
Master Detailer
Doesnt matter which way you put them. Left or right shock with left or right spring. Either will work.
Old Nov 8, 2010 | 10:52 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Just make sure the nut on the bottom of the spring fork faces the front of the car. Otherwise reassembly will suck.
D16SohcVtec
Mar 21, 2009 05:59 PM
TKAUTOMOTIVE
Oct 24, 2008 07:15 PM
E55TOSI
Honda Civic (2006 - 2015)
Oct 23, 2007 07:19 AM
samsong
Jan 19, 2007 07:24 AM
garados
Oct 31, 2002 02:52 PM
