Suspension & Brakes Theory, alignment, spring rates....
2001 civic /Acura brake problem
Old Nov 7, 2010 | 02:38 PM
waybel's Avatar
Default 2001 civic /Acura brake problem
Hi guys ,i just bought a 2001 Acura 1.7 EL which had no working brakes when i got it..Its has 4 wheel disk brakes.There was no brake fluid left in the master cylinder and the right rear caliper's piston was completely out because there was no brake pads left not even the metal nad the rotor was paper thin..I changed the 2 rear calipers ,rotors and pads,filled the master cylinder and tried bleeding the system.The front right and left rear bleed fine but the front left and right rear have no pressure.i disconnected the 2 main lines from the master cylinder to the abs box and there seems to be pressure from both.Could the proportion vave be stuck?If so any way to tell or can the valve be repaired?Could it be something else?Thanks
Old Nov 11, 2010 | 04:27 PM
Markb16a's Avatar
Default Re: 2001 civic /Acura brake problem
have you tried bench bleeding the master cylinder? And also I really don't know how to tell if a proportion valve is bad but there cheap at a local junk yard to get a replacement.
Old Nov 11, 2010 | 04:37 PM
waybel's Avatar
Master cylinder was the problem.I took the one from the parts car and all is good.
CarBug
Jun 12, 2016 01:51 PM
5rivers
Oct 10, 2015 06:44 AM
Tegraracer90
Jan 1, 2009 04:02 PM
tyro
13
Jul 20, 2006 08:08 PM
beeboyee
15
Nov 11, 2001 05:46 AM
