rsx mis-fire
Old Nov 7, 2010 | 06:53 AM
derke0324's Avatar
Default rsx mis-fire
so i got a 03 rsx type s and i recently had my knock sensor and o2 sensor fixed then the check engine light went off then it came on again for all cylinders misfiring and random misfire i changed the plugs and coil and still nothing the car drives fine no misfire when driving it just has rough idle idk what it can be any help would be apprecited thanks
Old Nov 7, 2010 | 07:23 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: rsx mis-fire
could be a map sensor going bad.
Old Nov 7, 2010 | 08:42 PM
WhiteOnRice's Avatar
Check the plugs. Swap around components. Sounds like a bad injector to me.
Old Nov 10, 2010 | 04:20 AM
RiotRCR's Avatar
I have/got a misfire, replaced plugs, coils, injectors, map... still there, in my thread they mentioned that poss the timing is off, could have had low oil pressure and jumped a tooth or something.
I haven't been able to get the timing checked, but that is another option.
Old Nov 17, 2010 | 03:42 PM
derke0324's Avatar
could it be a bad pcm i baught the car stock and the kid before had work done to it a flash on the pcm exhaust and header could the computer just be putting out the codes
Old Nov 21, 2010 | 08:01 PM
jmart41791's Avatar
I got those codes on my 04 turned out to be a burnt valve.
fronomo
Nov 22, 2012 04:31 PM
danielblushtein
Nov 10, 2010 12:12 PM
jdm91CrxSi
Aug 3, 2009 05:42 PM
Rkrd25
Oct 28, 2007 06:02 PM
