Suspension & Brakes Theory, alignment, spring rates....
Broken rear sway bar end links
Old Nov 7, 2010 | 05:22 AM
MelJ's Avatar
Default Broken rear sway bar end links
I've had the luxury of having to replace my SBELs. One of them has been broken for I don't know how long. One of the links is only hooked up to the bar and not the LCA. The problem is I can't remove them. I blasted them with PB Blaster and let it soak for a few hours. I realized I had to get a hex key/allen wrench and set it in the hole of the threaded piece in order to remove the nut. No dice. I couldn't get the damn thing to budge. I tried some locking pliers but not even that is helping. I really don't wanna have to cut these POS seized parts off unless it's a last resort. Is there another way to get these things off without having to break out the Dremel?
Old Nov 7, 2010 | 10:19 AM
98civdx's Avatar
Master Detailer
Default Re: Broken rear sway bar end links
Try a little bit of heat.
Honestly, id just cut them off.
Old Nov 7, 2010 | 10:29 AM
MelJ's Avatar
Yeah. Ended up doing that anyways. Didn't have a source of decent heat laying around either. I just wanted to know if there was another way around it before I got hacksaw crazy. Lol. Thanks though.
Old Nov 7, 2010 | 11:48 AM
wannaBjdmca6's Avatar
thry liquid wrench. it works wonders with a long 18 inch bar
2008fijibluesi
Honda Civic (2006 - 2015)
17
Apr 15, 2009 02:03 AM
chrisw85
Suspension & Brakes
Oct 24, 2006 01:02 PM
743power
Sep 16, 2006 01:53 PM
peja43916
Oct 15, 2005 07:14 PM
92 civic VX B18c
Suspension & Brakes
Apr 2, 2005 05:10 PM
