Crazy shake coming from my tire! help!
I was driving when suddenly my tire began to shake, almost as if it were flat. So i get out to check the tire, however it is not flat. i continue driving and more shaking. When i would turn left it would shake real bad, when turning right, the shake wasnt as bad, but was still present. And when i drove strait, sometimes it would barley shake, other times it would be a horrible (shake my whole car) type shake. My tire doesnt appear to be loose, and the tire has plenty of air... I need some help
1.Lugnuts
2.Tie rod
3.Wheel bearing
4.Ball joint
5.Bad axle
Could be a number of things, jack it up and shake the wheel to see where the wobble it mainly coming from and report back
2.Tie rod
3.Wheel bearing
4.Ball joint
5.Bad axle
b20bFourDoorCivicLX
May 13, 2012 09:19 PM
mikeunreal2
Mar 1, 2006 02:21 PM
