what valvesprings/retainers to use with skunk2 PRO1 cams?
Old Nov 6, 2010 | 07:24 PM
Cimburke23's Avatar
Default what valvesprings/retainers to use with skunk2 PRO1 cams?
well, i seaqrched and couldnt find anything directly speaking of this. I had put my engine together, ran 30 passes on the dyno, then made 4 passes at the track, and it pushed the locks through the retainers. I am not sure what brand retainers or springs were in the head, but they were not stock ones. I was wondering what is the best valvetrain to run with these cams, or if the s2 pro series are the only ones that will work correctly as i had been told that before but thought any aftermarket ones would be good. it had started pushing through on about 6 other valves also. it dropped a valve, broke it and broke 3 others, trashed the head, block and pistons and im trying to avoid that on the next build. any help would be appreciated. thanks
Old Nov 6, 2010 | 07:49 PM
2k.civic.si's Avatar
Default Re: what valvesprings/retainers to use with skunk2 PRO1 cams?
supertech springs/retainers....and check your retainers for wear on a regular basis.
Old Nov 6, 2010 | 10:01 PM
HAMOTORSPORTS's Avatar
^^ Supertech springs/retainers as mentioned above, or the Sk2 Pro springs/retainers. I've been running the Pro 2's on SK2 pro springs and retainers for roughly 15k without any problems. A local shop has been using supertech springs/retainers with sk2 pro 2 and 3 cams with great success as well. If you are going to be on a tight budget, the supertech combo is cheaper...
On a side note, it is possible that the wrong locks/keepers were used with your retainers. I'm not sure what brand, but I know I've come across aftermarket retainers that had to use specific keepers for the correct fit rather than OEM
Old Dec 22, 2010 | 03:35 PM
sh!ft's Avatar
Who the fack changed my title?!
would type r valvetrain and supertech valves suffice?
Old Dec 23, 2010 | 04:17 AM
kyden's Avatar
no.
Old Dec 23, 2010 | 07:25 AM
NinJa_FLiP's Avatar
^^ make that a HELL no.. lol.. well, itll fit, but nothing good will come of it =p
Old Dec 23, 2010 | 07:38 AM
Garrett's Avatar
With Pro series, I always use Pro series Springs/retainers
Old Dec 23, 2010 | 11:33 AM
a1320addict's Avatar
Ferrea 6000 Series, Comp Plus if you can afford it.
TeggieeTuner
Apr 27, 2012 06:37 PM
A.R
Oct 21, 2009 06:27 PM
kadidle
Nov 16, 2007 04:40 PM
boosted k20
Aug 26, 2005 03:25 PM
hYpE-R-29
Sep 21, 2003 11:41 AM
