215/45R16
Old Nov 6, 2010 | 06:39 PM
Droolin's Avatar
Default 215/45R16
Was wondering if anyone had this tire on their integra and how the fitment is.
Old Nov 6, 2010 | 06:48 PM
alphalanos's Avatar
Default Re: 215/45R16
How about wheel size, what model of tire, intended use, etc.
Old Nov 8, 2010 | 09:02 AM
nsxtasy's Avatar
H-T Order of Merit
They should fit fine unless your car is lowered a lot (e.g. more than 2"), in which case you're probably better off with 205/45-16.
Old Nov 9, 2010 | 05:49 PM
Droolin's Avatar
16x7 wheel summer max performance..basically a sticky street tire to keep traction probably going with the dunlop direzza star spec or something similar..my car is lowered more than 2 inches ill probably have to roll fenders and raise it some but just wanted some opinions on what other peoples experience was
Old Nov 9, 2010 | 06:02 PM
TunerN00b's Avatar
Since when does the Star Spec comes in a 205/45-16?!? Dunlop's website doesn't show a 16" size that is under 24" in diameter...
I almost went and bought 15s or 17s to run those tires, before settling on a set of RE-11s instead.
Old Nov 9, 2010 | 06:14 PM
95B18BTurbo's Avatar
I'm tucking tire all the way around with 215/45/16 on F&F2's Make sure you have a camber kit and you will have to hammer the front wheel well pinch weld flat. Other than that they will fit fine.
Old Nov 10, 2010 | 05:37 AM
nsxtasy's Avatar
H-T Order of Merit
Since your car is lowered a lot, you're better off with 205/45-16. Really sticky tires available in that size include the Bridgestone Potenza RE-11 and Toyo Proxes R1R.
jordanz
Oct 19, 2010 05:46 AM
1LowSOHC
Oct 18, 2009 01:23 PM
Naudlee
Apr 15, 2009 01:38 PM
YipMan_Style
Feb 12, 2008 03:43 PM
importtuner1413
May 26, 2007 10:46 AM
