h22a4 ckp??? HELLP
Old Nov 6, 2010 | 01:41 PM
sivtechatchy's Avatar
Default h22a4 ckp??? HELLP
I HAVE 95 ACCORD 95 PRELUDE DIZZY ON H22A4 CAN I TAKE OUT THE CKP ON THE H22A4 MOTOR SINCE ITS BUILT IN ON THE OBD1 DIZZY
Old Nov 6, 2010 | 10:53 PM
GhostAccord's Avatar
Default Re: h22a4 ckp??? HELLP
Yes. As long as you have the CKP & TDC sensors wired up from the distributor and the ECU is receiving the signals.
Old Nov 7, 2010 | 04:28 AM
ight thank you now wat ITM do i use since the accord doesnt have runner controls in them
Old Nov 7, 2010 | 04:50 AM
If you want electronic control you would be best to buy a 95 Prelude ECU and add the A17 wire for the secondary runner control (aka Intake air bypass - IAB) or you could hook them up mechanically. That way they run only off vacuum pressure vs an electronic signal. To do this you would hook the vacuum hose from the IAB diaphragm directly to a vacuum port on the upper portion of the intake manifold.
Old May 10, 2011 | 03:12 PM
sr.haakon's Avatar
this prob has nothing to do with this thread, but i have a 98 prelude base with a obd1 or obd2 jdm h22a swap and useing the stock obd2 h22a4 ecu. everything has been swaped from for the swap for obd2 but its still not starting turns over but wont start.. all the fuses are good any ideas?
RHD_BB4T
Mar 20, 2008 11:37 AM
lazerous163
Jun 14, 2007 05:29 PM
bdwvteconly
Feb 13, 2005 12:39 AM
HKSpowers
Sep 1, 2003 11:33 AM
black_sh
May 23, 2003 05:29 PM
