CA CA WTT/FS: 2JZ-GTE Lexus GS300 - Luxury Sleeper - Smogged - Clean Title
I am looking to trade my CLEAN TITLE 2JZ-GTE swapped, 95 Lexus GS300 Touring Edition for the following:
- Lexus SC300
- IS300
- Non-turbo mkiv supra
- CLEAN S14
- G35 Coupe
- S2000
If you have something else, please feel free to run it by me, but I am really interested in the above. Otherwise, I am asking $8,000 OBO. Please keep in mind that if your car is not worth anywhere near my asking price, I am going to ask for cash on top. If you feel it is worth more, let me know how much you would like. I can also make small adjustments to the price if I pull easily accessible parts off (ie. boost controller, wideband, rims, head unit, etc.).
JUST SMOGGED THE CAR.. Registration is current, all fees paid, tags good til May 2011. This means you can easily register it without having to smog it.
On to the details....
Engine & Exhaust:
- Aristo 2JZ-GTE Swap (Motor, Trans, ECU, etc. This swap was done right. Everything was done professionally, and no expenses were spared. This is the same motor and trans as the Mkiv Toyota Supra TT. The only difference is the cams, as they are slightly less aggressive and make for better daily drivability. The transmissions have also been known to handle 500hp with no problems.. and they shift FAST!)
- Single T70 Turbocharger
- Stainless Steel Tubular Manifold
- Tial Wastegate (9psi Spring, boost is currently set around .8 bar via EBC for daily driving)
- 3" Downpipe to full exhaust.
- HKS Dual Catback System
- Aluminum Radiator
- Huge Front-Mount Intercooler (Currently blacked out via radiator paint.. Bar & Plate - Good for ~600+HP)
- Trans Cooler (A definite necessity for the longevity of the transmission. Installed at the time of the swap.)
- Optima Battery
- Walbro 255lph Fuel Pump
- New water pump and timing belt
Suspension, Wheels & Brakes:
- LS400 4-Piston Brake Upgrade (Brand new pads)
- Tein Coilovers (Adjustable)
- 350z 18" Anniversary Edition Wheels
- Aristo Strut Bar
Electronics:
- $700 Blitz SBC i-Color Electronic Boost Controller (With real-time electronic boost-gauge) This thing is SICK.. you can monitor mph, rpm, a/f, boost, and a ton of other vitals in real time with this boost controller. Probably one of the best on the market.
- AEM Wideband O2
- HKS Turbo Timer
- Pioneer AVH-P4000DVD double-din head unit (Genuine Pioneer iPod hookup routed to center console)
- Car is pre-wired for a sub.
Lighting & JDM Goodies:
- JDM Headlights (With custom LED Running lights)
- 6k HID System
- JDM Tail Lights
- JDM Window Visors
- A/C Blows Cold as Ice
- Power Steering works perfectly
- Car idles and drives like stock.
- All electronics work.
- Receipts for swap + Maintenance + Most parts (Totaling WELL over 10k)
- Clean Title Pink Slip IN HAND.
Car is currently making around 375-400hp to the rear wheels, and only needs some larger injectors and tune to hit the 500+hp mark (with ease). Without touching anything, you can probably make upwards of 450 WHEEL horsepower if you turn up the boost.
Problems:
- Speedometer isn't working. No clue as to why.. figuring it is probably a bad needle motor... but, worst case scenario, it needs a speed sensor or a cluster (At max a $100 fix)
- Could use a better paint job, the one it has is not horrible, but if you are ****, you will probably want to get one done.
- The front seat bottoms need some love, as seen in the pics below.
Thanks for looking!
Pics:
Interior Shots:
Pretty much the only interior problem, a common Lexus problem.. and I have found a complete genuine leather replacement set that replaces every single piece of leather in the car, for $400 shipped. Installation is actually pretty easy, but I haven't really been able to justify spending any more money. I don't see the seats when I am sitting on them.. and they are just as comfy! lol
- Lexus SC300
- IS300
- CLEAN S14
- G35 Coupe
- S2000
Engine & Exhaust:
- Aluminum Radiator
- Optima Battery
- Aristo Strut Bar
Electronics:
- AEM Wideband O2
- HKS Turbo Timer
- 6k HID System
- JDM Tail Lights
- JDM Window Visors
Problems:
Thanks for looking!
Pics:
Interior Shots:
jdm ek o
Aug 9, 2011 04:43 PM
jayydeeemm
Sep 22, 2008 10:03 AM
