DC2 Shock and spring on DA9
Hello HT Members,
I have a DA9 which I am looking to upgrading my suspension soon. I have came across some post which mention about using a DC2 suspension on DA more specifically the shocks and spring. If i recall it mention simply use DC2 front lower forks and it will be plug and play.
Some mention of rubbing issue. I am looking for answer whom have actually performed this. Again I don't know if the rubbing issue was due to bent,tweak, front lower forks or a straight, good condition forks rub off the bat. Also it was mention the rear shocks off a dc2 will bolt up but will be shorter body;it was said it will benefit for drop vehicles but Im concerned on if it will give me the pre runner look which I dont desire.
Also my preference is lower then stock but functional meaning not slammed. Lastly it was said I could add a ITR LCA so spring and shock all around. Note I am planning out my suspension, I am planing to run new shock and spring set up but used front forks. Any first hand knowledge is appreciated. Thanks to all
