need install help
i have a 94 integra that im trying to install a head unit . i bought a kenwood head unit new from best buy ,got a new harness and solder the correct color coded wires together, grounded to the frame, turned the key and nothing. radio will not turn on checked ground, checked fuse in the radio checked, for power in the harness with a test light and has power . so i dono why the radio will not work any advice ?
Also, test for power on both sides of the harness. I've seen pins get jacked up inside of that harness, so I would get power on the car side of the harness on one wire, but no power on the radio side of the harness.
If you have power on both the red and yellow wires, and you have a good ground, then your radio is prob bad, and you need to exchange it.
thanks ill try that tomm and post back on results .. but im thinking something elese is wrong
..thats funny because this is the second radio i just exchanged the first one because i thought it was bad .
take your harness on the stereo and connect the red and yellow wire together. put the red and yellow to positive on the battery. put the black wire to negative on battery. the stereo should come on. if not the stereo does not work and check the fuse behind the stereo harness.
if the stereo work. check your car harness for power.
S2k Hybrid
Audio / Security / Video
May 3, 2007 11:15 PM
