Do strut bars help drivability?
Old Sep 21, 2002 | 06:28 AM
1990hondaHF's Avatar
Default Do strut bars help drivability?
Just wondering if one or both of these are worth buying. Do you all feel the difference? I included possibilities for those who put them on and didn't like them. Thanks.
[Modified by 1990hondaHF, 10:30 AM 9/21/2002]
Old Sep 21, 2002 | 06:33 AM
performula's Avatar
Default Re: Do strut bars help drivability? (1990hondaHF)
I hear about them, but for the price unless I was racing, I wouldn't buy them. I don't know anything about them. I've dumped so much $ already, I cannot afford them.
Old Sep 21, 2002 | 06:34 AM
slowman's Avatar
I took way too long
Get the ones on eBay. I have a front one and i could notice a difference. im getting ready to get the rear one real soon. and its only like $20
Old Sep 21, 2002 | 09:11 AM
HatchBox's Avatar
Skoobie no more...
Default Re: Do strut bars help drivability? (slowman EF)
ebay i got the front and rear for 60 shipped...cant beat that.
Old Sep 21, 2002 | 09:54 AM
E-AT_me's Avatar
Default Re: Do strut bars help drivability? (xxkenyon419xx)
only if you're racing should you even care about it.. then, when you ARE racing, you should get a NICE bar unlike e-crap ****.. i run neuspeeds on my car... the front one is NON-ADJUSTABLE which means it was DESIGNED to work with ONE car, not many.. it has no pivot points to lose structural rigidity.. with the back bar, it uses 4 bolts apposed to 2 to mount the bar to the actual rear mounting plates which cuts down on the amt. the bar can pivot...
Old Sep 21, 2002 | 10:41 AM
Soled Out's Avatar
Default Re: Do strut bars help drivability? (Lil cs zc)
I put on a rear and things seem alot tighter back there
Old Sep 21, 2002 | 11:08 AM
Brandon Chun's Avatar
Default Re: Do strut bars help drivability? (Boosted EF)
Yeah strut bars tighten up the chassis a bit, but they don't make the difference a nice rear swaybar will
Old Sep 21, 2002 | 11:18 AM
CWBETB's Avatar
Default Re: Do strut bars help drivability? (Brandon Chun)
Neuspeed Front and rear bars makes a huge difference in a hatch. Much tighter ride, makes the car feel solid I love them
Old Sep 21, 2002 | 12:36 PM
rurkster's Avatar
throw in a sway bar as well driveability goes way up, handles so much better
Old Sep 21, 2002 | 12:45 PM
ED8DX's Avatar
Default Re: Do strut bars help drivability? (rurkster)
Do the rear sway bar first and then spend some money on the neuspeed bars. I think the strut bars are like a finishing touch, last thing to do to complete the whole set up.
Old Sep 21, 2002 | 04:56 PM
hondacivic4g's Avatar
I put a front strut tower bar on my hatch. It made enough of a difference that i noticed as soon as i went through the curves. Think about it, under your hood you have a huge whole with no real solid brace going from one side to the other. When the body flexs most is due to the lack of solidity under the hood.So when you ad this brace, you force the whole front to have top flex as one instead of one side, creating a greater resistance.The rear is not a flexable due to the fact the roof acts as some what of a brace.
Old Sep 21, 2002 | 05:22 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: Do strut bars help drivability? (hondacivic4g)
Ive got front and rear strut bars and a lower tie bar. Let me tell you....they stiffened the car up ALOT. I had the expensive ones on my saturn and i have the cheaper ones on my car now and i can tell NO difference. The only way that you can tell a difference is if you were using it for race only. I say get the cheaper ones and save up for more go fast goodies
Sean
Old Sep 21, 2002 | 05:32 PM
TDRacing's Avatar
Default Re: Do strut bars help drivability? (sCeRaXn)
I have an OMP front bar, and it's very strong. I have been told that the backs dont make much of a difference, so i just got a high quality front one instead. if i need to strengthen up the back, i'll put a cage in.
Old Sep 21, 2002 | 10:06 PM
sparkz's Avatar
There's nothing wrong with the cheap ones. They function as intended and for the moeny saved, can get you the real upgrade that makes a difference, swaybar.
Old Sep 21, 2002 | 10:36 PM
boostinb18's Avatar
Default Re: Do strut bars help drivability? (sparkz)
[QUOTE]only if you're racing should you even care about it.. then, when you ARE racing, you should get a NICE bar unlike e-crap ****.. i run neuspeeds on my car... the front one is NON-ADJUSTABLE which means it was DESIGNED to work with ONE car, not many.. it has no pivot points to lose structural rigidity.. with the back bar, it uses 4 bolts apposed to 2 to mount the bar to the actual rear mounting plates which cuts down on the amt. the bar can pivot...QUOTE]
rexman is correct.......the purpose of a strut bar is to make a solid connection betweent eh strut towers, whe you buy a shitty strut bar that has pivot points and adjustable lenghts they dont work well at all!! maybe a little bit but way buy shitty parts?? remember this especially with your car YOU GET WHAT YOU PAY FOR!!!!!!
and the biggest difference youll feel will be a rear sway bar...go get one, suspension techniques makes a really nice bar!!
Old Sep 21, 2002 | 10:53 PM
RallySportCivic's Avatar
Default Re: Do strut bars help drivability? (boostinb18)
Im my civic I like the difference, but Mine is tied into the roll cage rear and front, but if you do get one, dont get none of that apc crap or anything like that. for what it is worth, dont get one unless you are racing your car.
Old Sep 21, 2002 | 10:56 PM
ijjz's Avatar
YEs they do . . be sure to spend alot of money on nuespeed
Neuspeeds are nice! I highly recommend these ones.
Old Sep 22, 2002 | 05:05 AM
MOCrxHf's Avatar
Default Re: Do strut bars help drivability? (ijjz)
I got DC but I wish I woulda got neuspeed
Old Sep 22, 2002 | 08:17 AM
primoEF's Avatar
cheap ones are good enough cause you won't tell the difference anyway, save the money for sway bars cause they make a hell lots difference
Old Sep 22, 2002 | 10:42 AM
REX VT's Avatar
Nah they don't help jack s|-|it , bars , cages all thrown away money
Old Sep 22, 2002 | 04:50 PM
Denny317's Avatar
I couldn't tell any improvement in drivability with my front and rear bars.
Old Aug 18, 2003 | 07:09 AM
Torino91LS's Avatar
Default Re: Do strut bars help drivability? (Denny317)
I would say front and rear Sway bars, and polyurethane bushings.
Old Aug 18, 2003 | 07:29 AM
EE9's Avatar
EE9
Turn in is SOOOO much better/responsive...
Got upper front & upper rear from Spoon... Lower front Cusco...
Old Aug 18, 2003 | 07:49 AM
etp72's Avatar
Default Re: (EE9)
Apologize to highjack your thread but
damn rear sway bars from neuspeed are expensive. $459.95 for the CRX
Wheres a good place to get them? I was looking at inlinefour.com
Old Aug 18, 2003 | 08:45 AM
SpoonFedEF7's Avatar
I got the spoon sports front and rear strut bars and i could tell a big difference. The spoon bars are very nicely made and the rear is lower than with most other brands as they go up over the push outs on the rear panels and the spoon requires you to cut part of the rear interior for it to fit. But it was well worth it.
