Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
High Prusure oil Pump on Civic SI 2011
Old Nov 4, 2010 | 01:38 PM
njmoro2's Avatar
Default High Prusure oil Pump on Civic SI 2011
Hi , first srry all mine english im still learning Ty .
Im looking for know if got any other Oil Pump for replace the original from civic si 2011 , i need one whif more oil pressure becouse i go make one K20z3 all motor for pass them 11.000Rpm , some peaople say for use Type-R Oil Pump but the oil pump is diferent from original and i go need adapt . any can help me ?
Old Nov 6, 2010 | 09:10 AM
bee guz's Avatar
Default Re: High Prusure oil Pump on Civic SI 2011
Oil pump pressure can be raised by changing the spring that controls the check ball, a stiffer spring in the pump will increase the pressure.
I think running 11K rpm's you would be more concerned with volume, a high volume pump in my opinion would be way better than just high pressure.
I used a high volume pump in my 4.0 jeep plow before I put the melling high volume pump in I had 20 to 30lbs at idle after the pump was in it pegged the needle when cold and ran 60 lbs hot at idle.
Circuit Star-29
May 5, 2006 09:40 PM
Circuit Star-29
May 4, 2006 11:44 AM
dohdoh420
Nov 26, 2005 09:02 PM
Griffin@Camtech
Apr 14, 2004 04:41 PM
