this doenst sound good
didnt check clearance but all the research that i have done says it there isnt anything conflicting with the swap.the cpr was bumped up one point, dont think i need tuning for it
Hmmm still a ping noise mean's a lean running motor that is about to pop soon.It will still drive fine but it is about to pop! Or it can also mean that the piston's are slappin the valves. Take off the head check the valves you can also put a small amount of puddy on the piston top.Put the head on and move the crank pully by hand then take the head off and see if they are making contact.
You'd be having bigger issues than that if your pistons were hitting your valves.
helpmeplease
Feb 17, 2011 06:01 PM
civic_99ex
Mar 10, 2010 07:50 PM
ToFu-DeLiVeRy
Sep 24, 2004 05:03 AM
ToFu-DeLiVeRy
Sep 20, 2004 07:19 PM
